Well, you'll need a heatsink for the CPU, so you should go with something that will make it last a while, like a nice silent Vantec Aeroflow, but you can check out www.AMD.com for their recommended list, but I always say to look for something that will cover a clocking speed higher than yours, that way you get "overcooling", because quite frankly, the cooler the better. Otherwise, you need an exhaust fan, but an intake is, I can't believe I'm saying this but, optional. I would DEFINITELY recommend one, as the additional $10 is worth it, for the life of your computer, because heat tends to kill performance a lifespan, but if you're not overclocking than don't go all out either.
