Archived from groups: microsoft.public.windowsxp.perform_maintain (
More info?)
Will, thank you thank you
for some reason during the os install on my new hd the srframe file didnt
want to come out and play. I found it on my os cd but couldnt extract just
that file so i burned it to another cd and presto i can know restore till im
blue in the face.
once again thank you ()n!()n
"Will Denny" wrote:
> Hi
> I've only got that file in the WINDOWS\system32\Restore folder. Search the
> hard disk/partition for that file to see if it is there, then point to that
> location when asked for it. Failing that, try the following with the XP CD
> in the cd drive, from Start>Run:
> expand X:\i386 srframe.mm_ c:\srframe.mmf
> where X is the letter of your CD drive. Then when asked for that file point
> to where you saved it to. That may or may not be the only file that has a
> problem being installed.
> Will Denny
> MS MVP Windows Shell/User
> Please reply to the News Groups
> "RaNc!D()n!()n" <RaNcDnn@discussions.microsoft.com> wrote in message
> news:9BDDCE15-1F0F-4D61-8CD5-8C6F4C57217E@microsoft.com...
> > hey Will
> > thx for the advice, however the action did not work here is a link to the
> > new result
http://img293.imageshack.us/img293/6663/error1ym.gif
> > thx
> > ()n!()n
> > "Will Denny" wrote:
> >> Hi
> >> Make sure that the System Restore Service is running.
> >> Try reinstalling System Restore. Open Windows Explorer and go to the
> >> windows\inf folder. In the right hand pane find the sr.inf file, right
> >> click on it and select Install.
> >> Will Denny
> >> "RaNc!D()n!()n" <RaNc!D()n!()n@discussions.microsoft.com> wrote in
> >> message
> >> news:50DC3D82-B0E6-4BF6-A187-E466CFA923B8@microsoft.com...
> >> >i recently lost my hard drives and have installed my new ones. my os is
> >> > installed XP...while setting up my tasks i tried opening restore so i
> >> > could
> >> > adjust memory usage but alas to no avail. here is a link to a shot of
> >> > the
> >> > errors. any and all help will be very much appreciated.
> >> > thanks all, ()n!()n
http://img368.imageshack.us/img368/2689/ss7ck.gif
