G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.perform_maintain (More info?)
My DVD/CD-Rom Drive has been experiencing problems (i.e. not
playing/installing disks when inserted). The light comes on, but will not
recognize the disk. After tech call w/ Dell, it was determined that it will
only recognize a cd/dvd one time (after restarting computer). After that, in
order for a cd/dvd to be able to be recognized & used, I must restart the
computer. The only ideas that were offered are to reinstall Microsoft Windows
XP, or to restore to a date/time before issue occurred. Neither are options:
either lose all information, or back up extensive data. Can anyone offer
assistance as to an easier fix? Please?
G
Guest
Guest
My brother had the same problem last week. The only solution I could get to
work was to format, delete the partition, repartition and reload Windows.
"TastefullyCasey" <TastefullyCasey@discussions.microsoft.com> wrote in
message news:5C3D7F78-EC0D-4706-8CF8-F29BFC464569@microsoft.com...
> will
> in
> Windows
> options:
G
Guest
Guest
John,
Can you give me some step by step on exactly what to do? The other option
was to restore system to a previous date, but I don't know when the problem
started. Maybe that would be easier than to reload Windows?? Did you find out
what caused the problem?
> > will
> > in
> > Windows
> > options:
Byte
1,199
Incorrect Contents Are Displayed in Windows Explorer
http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q314939
XP-WNP
Today is the first day of the
rest of your life.
"TastefullyCasey" wrote:
> John,
> > > will
> > > in
> > > Windows
> > > options:
