Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Alan,
Been a bit busy and this became a less urgent issue, but
I have to look at it again now. The computer is Windows
XP, the password option does not actually come up. We
are running off a Windows 2000 network with Exchange
2000. The printers are many and varied from HP, Kyocera,
Ricoh, you name it, we've got one of them. I'm having
trouble with setting up all of them. It is okay if I add
them normally to the computer through the network, the
problem only occurs when I am trying to add them as
default printers for when I set up new users. At the
moment if I set up a printer and add it to the default
user through the registry editor, and then create a new
user and try and edit the printing preferences I get
errors about the operation not working and messages about
the printer spooler is not running, when I know for a
fact that it is. Suggestions?
This posting is provided "AS IS" with no warranties, and confers no rights.
"Greg" <anonymous@discussions.microsoft.com> wrote in message
news:19c1e01c41d00$993417b0$a301280a@phx.gbl...
> Alan,
> Regards
> Greg
Alan,
Microsoft Knowledge Base Article - 307016. I followed
the instructions in that. I have since also found
another way of doing it which is a little easier at
But regardless of the method I get the same result. By
Windows 2000 I do mean the domain controllers. As far as
both explanations go there is no mention of drivers. Is
there a way of manually installing the drivers without
adding the printer? I mean, this sounds like a really
simple operation and something that really should be
easily achieved but seems to great all sorts of
nightmares.
>-----Original Message-----
>I am not sure how you are adding the printer using the
registry. Can you
>give a description of how you accomplish this?
>When you state Windows 2000 network you mean the domain
controllers are
>Win2k correct?
>How does the driver get installed for the printer when
you are using the
>registry to add the device (connection?).
>thanks
>Alan Morris
>Windows Printing Team
>Search the Microsoft Knowledge Base here:
>http://support.microsoft.com/default.aspx?scid=fh;
[ln];kbhowto
confers no rights.
message
>> Alan,
but
Windows
Kyocera,
add
about
>> Regards
>> Greg
