Solved
Skyrim Problem
Last response: in Video Games
Win7 ultimate 65
AMD FX-8120 @ 4ghz
Sapphire Radeon 7970 @ 1125/1575
4 x SATA HDD's
1x SATA SSD
gigabyte 990FXA-UD3 MOBO
8GB of Corsair 1866 ram
uhm.. My game looks sweet.. my problem is.. when i load into game.. my character runs stupid fast.. then the game slows down to normal speed.. then i start moving at lightning speed again..
this ever happened to anyone else? it just does it.. wasnt happening before i upgraded to this new rig..
More about : skyrim problem
Best solution
Your PC might be just a bit too fast, and Skyrim must be having a hard time keeping up! :lol:
LOL, just kidding.
Did you try enabling Vsync?
You'll have to go inside the Skyrim.ini file and then change the 'iPresentInterval=0' to 1.
it ended up being something out of wack with my overclocking settings in bios.. i was overclocked and turbo boost was on or somethin.. ive fixed it now though.. thanks for the reply
Glad to see you've fixed the problem.
Thanks for the BA. :)
Ask the community
