Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > DLINK DP-300U Port Setup Problems -- can not delete port
Forum Windows XP : Windows XP General Discussion - DLINK DP-300U Port Setup Problems -- can not delete port
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
PRINTER 1: Laser
After setting up port1 at 192.168.1.10 (Printer Server
Address) and the appropriate queue with LPR enabled.
PRINTER 2: HP D Series
2nd printer new Port same address, port name is queue name
lpxyzabc-U3 (Correct port name) ok, close, etc...
Now can not delete/configure port, says not supported
function, how do i delete/re-configure port????
Sponsored Links
If you are using LPR Port, there is no configuration UI. You also cannot
delete the Port until it is no longer associated with a printer.
Create a new port with the updated information. Set the printer to the new
port. Now you can delete the old port. If this is a port monitor from
DLink, I have not used this.
Alan Morris
Windows Printing Team
Search the Microsoft Knowledge Base here:
http://support.microsoft.com/default.aspx?scid=fh;[ln];kbhowto
This posting is provided "AS IS" with no warranties, and confers no rights.
"Dave" <Dave@ladouceurs.com> wrote in message
news:0c0501c425c1$32e21650$a101280a@phx.gbl...
> PRINTER 1: Laser
Reply to Anonymous
There are 1347 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
