Hey guys, A's u Can se im assing u about What quality my system Can run BF3 on, Specs: FX 4100, GTX 560 and 4 gigs 1333 mhz ram..
Sorry for bad english
Edit: All of my hardware rums on Stock speeds .
Is the 560 a non Ti? I will agree with the high and maybe some ultra. I guess that boiles down the resolution you will be using. Here is a little bench mark to help show both cards. Good luck to you.
In your link DM186, it shows me that with ultra and 1920x1080, it will have 46.5 fps, in average i guess? And if that is average it might sometimes drop to 30 fps, and would'nt it become a bit laggy then?
single player will get ultra settings but multiplayer need you to test and try different settings till you get to 60 fps minimum 1s you get there you will want to turn vsnc on
most likely you will get away with medium settings with ultra textures...
you can turn hbao off and set shadows to low as it will have little impact on visual quality but return a big improvement in fps...
No at 30 fps shouldn't give any lagging. It is when you go a lot lower that will bring on lag or if you have a heat problem then it doesn't matter what your fps are.
