I have a K6II 450. Can the system restart itself if the processor gets to hot? For some reason my system after in use for awhile it will restart it self in different spots for no reason. I thought it might be the CPU, the MOBO, or the Power supply. The case is brand new. Other then that I tried another mobo and it does the same. Only thing left is the processor! I am thinking maybe it doesn't have enough cooling and that is causing a problem!?!
If any one has any ideas, thank you!
Lars Coleman
Lars Coleman
