Printer problem
Forum Windows XP : Windows XP General Discussion - Printer problem
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I can't print on line or off. I have HP 2210. Faxing not
set up. I tried all advice in the printer, trouble
shooter/tool box. Usually solves any problem. It is set
for off line printing. I may have clicked this by
mistake. I can't find the solution to set it back. I
have windows XP. It was working fine earlier. I tried
Enable file & prit sharing IPX/SPX protocol. Froze after
clicking add. Ended program. I do have Norton System
works 2004. Not showing a virus. I do not know how to
download the patch listed for XP users posted on Symantec
last week. I dont know if this worm could be causing my
problems. Every time I print get failed to print error.
Can someone offer advice?
Thanks,
Kathy
Sponsored Links
I'm not sure why you have installed the IPX protocol, Windows XP only needs
TCP/IP and mixing and matching protocols is never a good idea.
Is this printer a local printer or a networked one?
Have you downloaded and installed all the Critical Updates from the Windows
Update site... is your antivirus software up to date and have you run a
complete scan?
Cari
MS-MVP Windows Technologies - Printing/Imaging/Hardware
www.coribright.com
"Kathy" <anonymous@discussions.microsoft.com> wrote in message
news:c67701c438ba$4e5089b0$a001280a@phx.gbl...
> Thanks,
> Kathy
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Printer problem
There are 1319 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
