Tom's Hardware > Forum > Systems > Compaq > Armada 7380DMT with external cd-rom boot problem
Forum Systems : Compaq - Armada 7380DMT with external cd-rom boot problem
Archived from groups: alt.sys.pc-clone.compaq (More info?)
Hello,
This is my first compaq laptop I try to repair.
The problem is, I can not go into the bios to look for de external cd-rom.
When I use a diskette, I never come to the cd-rom drive. The cd rom drive is
conected by a pcmcia-card.
But when I have the bootcd in it, it will not go to the cd-drive.
I even cannot go to the bios to make it happen.
Can anybody tell me how to get in the bios??
I already tried pushing several knobs at boot, even with the ctrl pushed in,
but nothing helps.
Anybody an answer for me???
TIA
Jan
Sponsored Links
"J. Elzinga" <j.elzinga11NOSPAM@chello.nl> wrote in message
news:QiW8d.6113$Ye1.4690@amsnews05.chello.com...
> Hello,
> cd-rom.
> rom drive is conected by a pcmcia-card.
> pushed in, but nothing helps.
> TIA
> Jan
If you still have the original Compaq supplied hard drive installed,
there is a diagnostic partition which has the BIOS setup
information. This is accessed by hitting the <F10> key while the
cursor is flashing in the upper part of the screen. You have to
practice the timing of the key press. If the original drive has
been replaced, you have to download a floppy disk based BIOS Setup
routine from Hewlett-Packard.
No computer has native support for PC cards at the BIOS level. The
PC card services are loaded with the operating system, usually
Windows and not MS-DOS. There are Linux and MS-DOS drivers
available but the boot sequence is well advanced by the time they
are loaded. There is usually an audible tone when PC cards are
activated. The bootup options are the hard drive or a drive in the
multibay, half-height bay or a bay in a docking station. You would
have to replace the floppy drive with a CD-ROM drive to boot from
it.
Earl F. Parrish
Reply to Anonymous
"Earl F. Parrish" <efparri@nowhere.world> schreef in bericht
news:V619d.14083$Xk1.6434@trnddc02...
>> Hello,
>> cd-rom.
>> TIA
>> Jan
> If you still have the original Compaq supplied hard drive installed, there
> is a diagnostic partition which has the BIOS setup information. This is
> accessed by hitting the <F10> key while the cursor is flashing in the
> upper part of the screen. You have to practice the timing of the key
> press. If the original drive has been replaced, you have to download a
> floppy disk based BIOS Setup routine from Hewlett-Packard.
> No computer has native support for PC cards at the BIOS level. The PC
> card services are loaded with the operating system, usually Windows and
> not MS-DOS. There are Linux and MS-DOS drivers available but the boot
> sequence is well advanced by the time they are loaded. There is usually
> an audible tone when PC cards are activated. The bootup options are the
> hard drive or a drive in the multibay, half-height bay or a bay in a
> docking station. You would have to replace the floppy drive with a CD-ROM
> drive to boot from it.
> Earl F. Parrish
Thanx It worked, smile
Jan
Reply to Anonymous
There are 538 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
