I didn't actually do the mod, myself. I just passed on the link. 4-5 degrees higher puts your cooler in FOP32 territory. You didn't say what temperatures you are getting but it is quiet which is what you requested.
I have an Enermax 80mm fan that seems pretty powerful. I'll see if I can find the specs on it. It has a useless thermal sensor/switch which brings the fan up to full speed at 85 degrees C but this can be defeated by cutting and shunting the leads. The fan must be designed for a power supply. Keeps my case nice and cool, though.
Better than the Enermax, I think Delta has has a 4800 RPM 80mm fan. This should be an excellent compromise to low noise and good cooling.
