Hi Everyone,
Firstly I apologize if this is in the wrong forum, you are welcome to move it.
Okay, so ever since I have been playing swtor I have had nothing but terrible FPS (20-27ish with everything on Low).. This seems very odd to me and a few mates since I can easily run Battlefield 3, Metro 2033 and Starcraft 2 on high settings with no issues.
The following are the details I know about my PC, if you require any additional information, feel free to let me know...
CPU: AMD Phenom II X6 1090T
Graphics Card: Gigabyte HD6870 1GB GDDR5
Ram: Corsair Vengeance 16GB (4x4GB) 1600MHz DDR3
HD: Ocz Agility 3 SSD 120GB
Power Supply: Corsair TX750W
Motherboard: Gigabyte GA-990FXA-D3
Case: HAF X
OS: Windows 7 64-Bit
I have tried on every resolution under the sun, different settings from top to bottom, reset ATI Catalyst to factory defaults, Defrag, clean up of harddrive..
A mate and I run tests and nothing seems to be 'bottlenecking' so to speak, all the temps stay fine. The FPS is terrible like to the point where I have to put everything on bare minimum to even play and it still chugs my system.
The CPU with all 6 cores stays under 30% usage when swtor is up, the memory barely moves and the GPU stays below 60 degrees and 30% usage aswell but yet the performace is terrible..
I appreciate any and all help with this matter.
Case: HAF X
