G
Guest
Guest
Ok I just got a D750 and im running it on a K7VAT MOBO with the VIA KT-133 chipset. The board has switches on it to set the clock higher and a jumper that tells the board to use the MB clock setting instead of the chips, however it doesn't change the speed of the chip. Is that becuz i havn't connected the L1 bridges, i don't know. I've heard of some people who OC without connecting the L1's but i was unsuccessfull. If I do OC my next question is what should temperatures should I want to keep the chip at. right now its running at 80-90F, I have a dual fan heat sink with an orb type design. and two huge server fans for the rest of the system. here are my specs
D750
K7VAT (Via KT-133 chipset)(not a great board i know)
2 PC133 128mb and 1 PC100 64mb for total of 320mb
G-Force 2 MX 32SDR
I think thats all that would have a major effect on the OC, both my HD's are a couple years old so no real heat coming from them. Thanks for any help you can offer
D750
G-Force 2 MX 32SDR
