Solved
Razer Naga problems
My razer naga is making my computer freeze and go to a blue error screen every time I press one of the side buttons!Is there anyway to fix this??
5 answers Last reply Best Answer
More about razer naga problems
  1. download drivers, that or uninstall and reinstall, see if that helps.
  2. Hi :)
    NEW mouse needed....
    All the best Brett :)
  3. Brett928S2 said:
    Hi :)
    how does that help him? why dont you buy a $70 mouse and just get a new one if it dont work first try.
  4. Best answer
    install the drivers from razer site and also get the firmware updater.
    1s the drivers are installed you can test again if the system bsods then update the firmware if its a newer version. if it still bsods then make sure you turn off usb mouse support in bios. this wont affect the mose working in windows but it will stop the pc from looking for it and loading the default hardware driver which has been known to cause bsods with certain usb mice.
    good advice here, follow this. im tired of BRETT an his one line nonsense. help people or dont comment please. quit just posting to raise your status. 5 months, an addict? please. :fou:
PC gaming Computers Razer Video Games
