G
Guest
Guest
Everybody know that by leaving one side of the case open, the CPU and motherboard temperature drop. In my case 9 degrees. Come to think of it, why didn't anybody suggest cooling a CPU by leaving one side open instead of install a black-label Delta? After all, install a Delta may lower CPU temperature by 5 degrees or more when comparing with other fans. And leaving a side open can do the same trick without the noise. Delta is driving me crazy.
***Warning: Leaving a side open doesn't mean that you can run your computer without a Heatsink & Fan***
