Ok fellas here it is. Short and sweet, allowed 5 minutes after bootup to cool down, then did 10 minutes under Seti@home. Used Sisoft Sandra 2001 motherboard information.
Room temp was 75F
133x7.5 = 997mhz 1.75v Changed to stock for the test.
Setup 1: 2 intakes rear, 2 exhaust front, heatsink down
Idle temps Load Temps
C F
Board Temp : 25.4C/77.7F 25.4/77.7
CPU Temp : 27.2C/81.0F 35.3/95.5
Power/Aux Temp: 29.0C/84.2F 29.9/85.8
Setup 2: 2 intakes front, 2 exhaust rear, heatsink down
25.0/77.0 25.0/77.0
29.4/84.9 37.1/98.8
27.6/81.7 26.7/80.1
Setup 3: 2 intake front, 2 exhaust rear, heatsink up
25.0/77.0 25.0/77.0
33.9/93.0 38.0/100.4
26.3/79.3 26.7/80.1
Setup 4: 2 intake rear, 2 exhaust front, heatsink up
25.4/77.7 25.4/77.7
33.4/92.1 39.0/102.2
28.1/82.6 29.4/84.9
As you guys can see that the 2 intake front, 2 ehaust rear produced better board temps and aux temps, but the intake rear produced the better cpu temps. Personally I think the extra .2C board temps is well worth the 2C cooler CPU temps. I believe this is a direct reflection of the cooler air from the rear intakes being closer to the sucking of the heatsink fan. When you intake from the front, the heatsink is only getting ambient board temp air versus wind chilled air directly from the intakes above it. At least thats my take.
"It takes a big man to cry, it takes an even bigger man to laugh at him."
