CS:GO w/ GTX670 Frame rate drop/lag spikes issue need Help!
- PC gaming
- Video Games
Last response: in Video Games
jayfx2
May 18, 2012 7:03:48 AM
Hi, just upgraded my graphics to a GTX670 and my framerates on GO is horrible. I have the video settings on default and I'm getting anywhere from 10fps to 100+ fps. The framerates jumps up and down randomly. Has anyone else has this issue before? My setup far exceeds the requirements for this game so it shouldn't be a hardware issue. Also this was tested offline with bots so I don't know how good or bad multiplayer would be. I am running on AMD PhenomII X4 965 cpu if that helps. Let me know, if anyone has a solution
More about : gtx670 frame rate drop lag spikes issue
Reply to jayfx2
Condoriano
May 18, 2012 7:05:13 PM
I dont have a nVidia card. But i hope i can help.
Did you try to turn off vSync?
I read something like your issue here: http://www.tomshardware.com/news/GeForce-GTX690-GTX680-...
Reply to Condoriano
m
l
bystander
May 18, 2012 9:41:35 PM
The problem is likely the fact that Counter Strike is a very old OpenGL game. Modern video cards or at least Nvidia and AMD, have pretty much abandoned OpenGL on their video cards. The rare occasion an OpenGL game is released, they will update the drivers so that they game will perform well, but with such an old game, these new cards are not optimized to handle the OpenGL.
Reply to bystander
m
l
- Need help with frame-rate issue! - Forum
HEXiT
May 18, 2012 11:05:09 PM
cs global offencive is a new game m8. its based on the updated cs engine so is well supported.
my guess is its cpu related. if your running an fx based setup then thats most likely to be the cause due to the game not using all the cpu resources and running off 2 threads which the fx cpu's just dont do very well and will bottleneck higher end cards...
try running a more thread demanding game like bf3 of badcompany 2 to see if your getting low fps on them games. if you have em.
Reply to HEXiT
m
l
bystander
May 18, 2012 11:17:34 PM
From what I tell, CS:GO is in beta. Is this true? Are you playing a beta version?
Again, AMD and Nvidia almost never release their OpenGL updated drivers for a particular game until right before the release of the game. Since it is not released yet, the drivers are likely not optimized for the game.
If I'm wrong, you can ignore what I wrote.
Reply to bystander
m
l
jayfx2
May 19, 2012 12:19:38 PM
jayfx2
May 19, 2012 2:15:49 PM
bystander
May 19, 2012 2:48:23 PM
jayfx2 said:
I updated my mobo bios and it seem to fix the issue of low frame drop in the beginning but I still get frame drop throughout the game at times. I am guessing it is CPU issue like with the FX series. Maybe the PhenomII are affected tooThere is a vary good chance that it's a driver issue with the GPU. Look at games like Rage, which ran awful at release, because the drivers were not ready. That is because games like Rage are OpenGL, and AMD and Nvidia just do not support OpenGL with their gaming cards except on a game by game basis. You'll have to wait until release to really know.
Reply to bystander
m
l
pls gooby
May 24, 2012 12:53:34 PM
jayfx2
May 31, 2012 3:35:49 AM
sadjungle
December 17, 2012 2:35:48 AM
nabendu
September 29, 2013 7:23:37 AM
Stickem
September 30, 2013 9:34:59 AM
All of the answers above are incorrect. Valve has identified a memory leak issue, specifically with nvidia branded cards, that is causing frame rate loss especially after the "Arms" udpate was released. It isn't your video cards problem, instead it's Valves stupid issue. Please keep in mind that CSGO is a ongoing beta testing ground for Valve to further test the Source engine. So, they are constantly screwing with things and it is causing issues with some clients. For further information, visit the steam forums and search for forums posts related to this. As of right now, there is a small fix that you can add to the the start command for CSGO called "-processheap" It seems to fix the issue for the most part but some users still get the occasional fps loss. Anyways, have fun waiting on Valve to get off their rear ends and fix the issue.
Reply to Stickem
m
l
nabendu
October 3, 2013 8:21:19 AM
VibronicJumper
July 7, 2014 9:54:05 AM
I had the same problem but there is a fix that I stumbled upon by accident. Check and see if any of your CPU cores are parked at all. If they are, then unpark them. You can see if your cores are parked by checking your resource monitor on windows, just go to the CPU tab and scroll down reading the right side. Some cores will be labeled as parked.
Reply to VibronicJumper
m
l
Read discussions in other Video Games categories
