Presario 12XL510A max bus speed
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.compaq (More info?)
Hi, this laptop ships with a P3 with a 100 mhz bus speed. Would that be the
limit for the motherboard (which I am buying separately) or would it take
133mhz?
Thanks again....
hh
645
Depends on the motherboard chipset used. If it's an Intel 810, likely 100MHz
is the limit. If an 810E or VIA 694X, 133 should work.
HH
"BROUGHCUT" <broughcut@aol.comdrop> wrote in message
news:20041020122241.10984.00002101@mb-m14.aol.com...
> the
> 133mhz?
> Thanks again....
