G
Guest
Guest
I was thinking about how to make my own water block when this idea hit me: Why use a water block at all? If I glue a chipset heat sink onto the CPU and construct a box over it, then I can run water directly over the chip. The resistors can be coated with silicone and unless the CPU chip can rust, there shouldn't be any problems - right?
(I posted this because I'm wondering why I haven't heard of anyone doing this before - please tell me if you think of something that could go wrong
-jtm
-jtm
