I recently downloaded a mod that replaces the meshes, textures and animations in skyrim that makes it so ALL weapons are on the back. For some reason when I use it, the weapons are somewhat glitchy and gets very annoying. I want to remove it but there isn't just an .esp file I can uncheck, it replaced all the meshes and stuff. Is there a way I can get it back to normal? Can I redownload the vanilla files or is there a mod that would bring it back to normal?
I NEED HELP
Thank you for your time
I NEED HELP
