Hi!
I used to have a AMD Thunderbird-B 1.1Ghz (1100Mhz/100Mhz FSB) and i unlocked without a problem, at first try, with a pencil lead.... it was an AVHA core
Now i've changed it to an AMD Thunderbird-C 1.1Ghz (1133Mhz/133Mhz FSB) and i unlocked at first try with the same pencil lead.... it's an AVIA core
But i have a problem though..:
I have an Asus A7V133 with the latest BIOS (1.0.0.5)
When i boot, the DEFAULT setting for the CPU on the BIOS is 8.5x100Mhz (850Mhz).... the multiplier is correct but the FSB isn't (should be 8.5x133Mhz)..
I can sucessfully set it at 8.5x133 with no problems, i can use ANY multiplier and ANY FSB, and i can get it up to 11.5x133Mhz (1530Mhz, doesn't boot at 12x) or 10x150Mhz (1500Mhz)...
Now, if it's completelly unlocked, why does it boot for default at 8.5x100?? The "i've bought a TB 850Mhz for a TB 1.1Ghz" doesn't work since it works at 1.5Ghz and before applying ASII i checked the A1133AVIALALAL3C tag on the core.....clues anyone?
Don't believe blindly in what you hear! - Play safe! Play hard!
