I have a somewhat irritating problem with my new a7v133 and 1.33 Ghz 'c' T-bird. I can't seem to even clock up to the 1.33 G clock through bios. I can up the FSB to 145, but when I try to kick up the multiplier more than 8.5 with ANY FSB, it won't even boot, even with the vcore at 1.8 (the max that the a7v133 will do thru bios). I pulled my SBlive 5.1 and US Robotics modem out, had to leave the new asus v7700 in to see what was happening. I have Micron pc133 cas2 ram. Heat doesn't seem to be an issue, with the latest asus pc probe I never go over 50c (mb is 31c) with my Volcano II. My WIN 98 even re-loaded all my drivers after one aborted "up-to clock". I can't even clock it to spec, let alone OC'ing it. But, my v7700 seems to OC ok. I notice that asus will automatically drop the PCI multiplier to 1/4 with FSB over 120, so I don't think PCI/AGP clock problems are the cause.
I don't know if I want to using the dip switches if I have to go thru the asus 'safe mode' boot as often as I am.
Is it my attitude?
Paul Kaski
Is it my attitude?
Paul Kaski
