G
Guest
Guest
is the weight of heavier copper heatsinks something i should be worried about in buying a new hsf? for example, global win's cak38 weighs about 450 grams according to most of the info i find, and amd says that your hsf should not exceed 300 grams. is the extra weight only a problem when transporting a machine, or is it something to worry about even when your case is just sitting on the floor? and how much weight is too much? the new swiftech is gigantic and it just worries me, putting that much stress on the socket. and finally, is the extra weight even worth it? will the cak38 really do about the same job as the fop32-1 or the fop38 as seems to be the case from tom's cooler comparison? and what about the noisecontrol silverado? according to tom's comparison it outperforms all of the global win models i listed. so you know, i am running a 1.2ghz athlon, and am planning to oc it in the near future as soon as i get my cooling situation figured out. any input or information would be appreciated.
--renfield
--renfield
