G
Guest
Guest
How would one go about setting up a water cooleing system that would cool the CPU and the video card. A really bad example that was in the Koolance review:
http://www.tomshardware.com/cpu/01q3/010706/images/grafik.jpg
In that example, the heated H20 seems like it heads straight for the video card. Perhaps this is one of the many reasons for their system instability. Anyway, how could one go about cooling both? Is it possible to use a y-adapter to split the output from the pump so that h20 is pumped to both locations? Would this get around the problem that hot water would leave the cpu and head for the GPU?
