[New Build] Hackintosh build - cross post from new build
Firstly, sorry for posting in this category. I got no help in the new build area, and I assume its because they don't work with hackintosh. Check it out:
Hey Tom's Hardware. This computer is for my sister. It took me months to convince her not to dish out thousands on a mac pro, and she said I could build her a computer on the condition that it is a hackintosh. She will be working with very high resolution drawings, but I don't want her to be held back if she decides to go into 3d or if she wants to edit a movie. If a more expensive component will keep up with software longer, then I consider it an advantage. The parts MUST be hackintosh compatible. I will be installing Lion onto it. Ideally, I want it to be cheaper, and far better than a mac of similar caliber. I've included all my current part options, and additional necessary information below. Let me know what you think!
PARTS
Intel i5 2500k
http://www.directcanada.com/products/?sku=12200BD1527
Asus P8P67 M Pro
http://www.directcanada.com/products/?sku=10530BD0992
ASUS Radeon HD 6870
http://www.directcanada.com/products/?sku=10530BD9927
G.Skills Ripjaws DDR3-1600
http://www.directcanada.com/products/?sku=15380BD5211
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811129021
ASUS VS248H-P Black 24" 2ms HDMI LED Backlight Widescreen LCD Monitor 250 cd/m2 ASCR 50,000,000:1
http://www.newegg.com/Product/Prod [...] 6824236153
OCZ Agility 3 120GB 2.5IN SATA3 Sandforce SF-2281 SSD Solid State Disk Flash Drive
http://www.directcanada.com/products/?sku=16950DR5133
Western Digital Caviar Black 1TB SATA3 6GB/S 7200RPM 64MB Cache 3.5IN Dual Proc Hard Drive OEM
http://www.directcanada.com/produc [...] ital%20WD]
OR
Seagate ST310005N1A1AS-RK 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Prod [...] 6822148321
PSU???
CPU Cooler???
Peripherals??? (Mouse, Keyboard, Speakers)
Anything I'm missing???
INFORMATION
Approximate Purchase Date: this week
Budget Range: 800-1500 (can exceed if there's a distinct advantage)
System Usage from Most to Least Important: Illustration (photoshop, zbrush, other programs), 3d programs, possible video editing, business
Parts Not Required: All parts required.
Preferred Website(s) for Parts: Direct Canada is first, Canada Computers (store), Newegg, Tiger Direct
Country: Canada
Parts Preferences: I am a fan of Asus, but my mind is open. I want to run the OS off of an SSD, but have most of the files on a separate 1TB HDD. The monitor must be 24 in or larger, have a good image (Asus is a plus). Need a flat keyboard (the keys need to have a low profile). RipJaws ram is first choice, but alternate options are welcome.
Overclocking: No
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1200 Preferred
4 answers Last reply
More about build hackintosh build cross post build
  1. PSU : http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095
    CPU cooler : http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099
    Keyboard : http://www.newegg.com/Product/Product.aspx?Item=N82E16823109063
    Mouse : http://www.newegg.com/Product/Product.aspx?Item=N82E16826153055
    I sugest you if you do Illustration (photoshop, zbrush, other programs), 3d programs, possible video editing the i7 2600k and Nvidia card for Cuda.
  2. So i7 2600k > i5 2500k for illustration and vid editing? Thanks for the input, do the other components look good?
  3. It's alright, just make sure even if it's a high end components, the consequence is if there aren't driver yet for the new hardware's.
    PARTS
    Intel i5 2500k
    Asus P8P67 M Pro
    ASUS Radeon HD 6870
    OR
    PSU???
    CPU Cooler???
    INFORMATION
    Country: Canada
    Overclocking: No
    If I were you, I would post this same message at tonymacx86 web site. I believe you may have problems with your video card, but I am just new at this. I was recommended to buy a 6870 with a layout port of 1 x HDMI, 2 x mDP, and 2 x DVI. I hope this will help you before you buy anything. Please, do yourself a favor, and go to that web site to get help.
Configuration New Build Mac OS X
