G
Guest
Guest
Ok, before anyone yells at me, I spent an hour reading the boards and have not found my exact problem. Im running an MSI K7T266 RAID Mobo with a 1.4 and when I OC even as little at 1.5 I get explorer and general lockups. My setting is 135x11=1485, which the BIOS and everything else sees as 1500, and when I run 137x11 it tells me 1533. Ive jumped the voltage in BIOS up to 1.775 and it that didnt work. Im cooling with a highly ventilated case, an Antec SX1030B with 2 rear fans, a 32CFM in front and a 36CFM sunon blowin over the RAID drives. Processor cooling is handled by an OCZ gladiator with delta fan, copper shim and OCZ quicksilver. Heat does not seem to be the problem as temps are usually under 48 at load. Im kinda nervous about jumping the voltages up any higher, but is this my best bet? Thanks!
MSI K7T266Pro Raid 0
1.4 tbird
256MB Corsair PC2100 DDR
OCZ GLadiator with Delta a shim and some paste
2x WD ATA100 7200 RPM HDD in RAID 0 config
Geforce3
Antec 300 watt PS
<font color=purple><b>Its not easy being purple</b></font color=purple>
<font color=green><b>AMD</b></font color=green>
1.4 tbird
Geforce3
Antec 300 watt PS
