Archived from groups: microsoft.public.windowsxp.print_fax (
More info?)
The usual fix is to install Windows XP Service Pack 1. Certain registry
keys on which Fax depends can be wiped out by certain update or repair
operations in XP and causes this behavior. SP1 fixes the problem.
Alternatively:
1. Save the attachment to this post (or paste the text between dashed lines
at the bottom of this message into Notepad and save it).
2. Rename it RPCProt.reg
3. Go to Windows Explorer and double-click on RPCProt.reg - this would apply
the key to the registry (assuming that Merge is the default action).
3a. If double clicking the RENAMED file opens Notepad or WordPad, go to
'Start|Run', type REGEDIT, click OK, then go to 'File|Import' and navigate
to the file.
4. Stop and then restart the fax service.
The contents of the attached file:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Rpc\ClientProtocols]
"ncacn_np"="rpcrt4.dll"
"ncacn_ip_tcp"="rpcrt4.dll"
"ncadg_ip_udp"="rpcrt4.dll"
"ncacn_http"="rpcrt4.dll"
Hal
Hal Hostetler, CPBE -- hhh@kvoa.com
Senior Engineer/MIS -- MS MVP-DTS -- WA7BGX
http://www.kvoa.com -- "When News breaks, we fix it!"
KVOA Television, Tucson, AZ. NBC Channel 4
Got Blues? -
www.badnewsbluesband.com
"Jan Works" <jan@works-words.com> wrote in message
news:uTj$YsgdEHA.1184@TK2MSFTNGP11.phx.gbl...
> I hope someone can point me in the right direction.....
> The fax printer is installed, the modem query returns, and in fact I sent
a
> fax using the Send a Fax Wizard. The recipient called to confirm its
> receipt. However, the Fax Monitor didn't appear during transmission--it
was
> configured to do so-- and the sent fax doesn't show up in the Fax
Console's
> "Sent" folder. I am unable to import sent fax messages from their store
> folder....it just keeps cycling past the number it indicates are being
> imported, and I have to Cancel. The Fax Console status line says "All fax
> printers are inaccessible."
> This all worked just fine last week; a few days ago I had to do an OS
repair
> (XP Professional) because of another problem and Fax hasn't worked since
> then. It won't answer the fax line, even though configured to do so. Yes,
> SP1 is installed and I don't run NIS.
> In which order do I need to remove modem, fax printer, and Fax Console and
> reinstall. Or am I past being able to fix it that way. Will I have to edit
> the registry?
> Help!
> (and thanks)
> Jan
begin 666 RPCProt.txt
M__Y7`&D`;@!D`&\`=P!S`" `4@!E`&<`:0!S`'0`<@!Y`" `10!D`&D`= !O
M`'(`( !6`&4`<@!S`&D`;P!N`" `-0`N`# `, `-``H`#0`*`%L`2 !+`$4`
M60!?`$P`3P!#`$$`3 !?`$T`00!#`$@`20!.`$4`7 !3`$\`1@!4`%<`00!2
M`$4`7 !-`&D`8P!R`&\`<P!O`&8`= !<`%(`< !C`%P`0P!L`&D`90!N`'0`
M4 !R`&\`= !O`&,`;P!L`',`70`-``H`(@!N`&,`80!C`&X`7P!N`' `(@`]
M`"(`<@!P`&,`<@!T`#0`+@!D`&P`; `B``T`"@`B`&X`8P!A`&,`;@!?`&D`
M< !?`'0`8P!P`"(`/0`B`'(`< !C`'(`= `T`"X`9 !L`&P`(@`-``H`(@!N
M`&,`80!D`&<`7P!I`' `7P!U`&0`< `B`#T`(@!R`' `8P!R`'0`- `N`&0`
M; !L`"(`#0`*`"(`;@!C`&$`8P!N`%\`: !T`'0`< `B`#T`(@!R`' `8P!R
7`'0`- `N`&0`; !L`"(`#0`*``T`"@``
end
