Answer to the MSCONFIG Problem
James35
367
Easy fix people, for those of you having a ton of programs starting up as you start win2k.
goto.
www.zdnet.com
search for STARTUP COP
Download that program and stick in your windows. :)
Works great, Been running it for awhile now with no problems at all with it.
James35
367
just bringing this back to the front for another day, so others can see it a bit longer before it goes by the wayside, and ppl reask the msconfig question :)))))))
G
Guest
Guest
Does this work win 2000?
I read the readme after downloading and it didn't mention 2000.
