Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Need expert advice on case cooling strategy
Forum Overclocking : Cooler and Heatsinks - Need expert advice on case cooling strategy
I'm building a new system. I've been doing some preliminary research, and I think I've decided on the Coolmaster ATC-101 for my case. I need helping devising a strategy to cool my cpu and system. I don't know which PS, internal fans, hs, or hsf to get, or how many for that matter. Money isn't an object, but practicality is......to a degree. So if it were up to you, how would you do it?
BTW, I'm thinking on a TB1.3 with minor ocing, running on an Abit kg7.
Sponsored Links
Go for an Enermax PS (300-350W should be enough, its up to you) since they are good quality and have a fan intake on the bottom (over CPU). Add a good 80mm for a frontal intake of air (Sunon, thermaltake, Delta), at leats an outtake on the back (besside PS)(you casing supports 2 back fans) an I think your tower has room for a third one on top.
As for HSF, many people seems to say that the Volcano2 is a cheap AND reliable cooler if you are no hardcore overclocker.
Reply to Zenthar
if moneys no object and you want a quiet cool case... get the vapochill or the like...
you do not strengthen the weak by weakening the strong
Reply to killall
There are 970 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
