Sign-in / Sign-up
What is problem with battlefield 3?
  • PC gaming
  • Core
  • GPUs
  • Video Games
Last response: in PC Gaming
June 8, 2012 5:51:56 AM
I have core 2 duo e7500 @3.1Ghz
nvidia gt9400 gpu clock- 800Mhz
Memory clock-440 Mhz
Shader clock- 1.8Ghz
Ram-3GB DDR2
Board-Asrock g41C-VS
i playing BF @ all low setting expect Textures its on high still game is very slow
when i check cpu usage i see that core is @100% temp 96C and core 2 34% temp 84C
well offcourse gpu usage is 100% gpu memory usage 650MB
please give a advice to play it on a playable speed
More about : problem battlefield
June 8, 2012 6:46:21 AM
Both the CPU and GPU are really getting worked. I suggest lowering your resolution, and play on Medium settings modified, some settings have to be lower. Also turn off antialiasing and ambient occlusion.
m
l
June 8, 2012 11:17:14 AM
but cant you tell why core 2 is not having much usage?
m
l
June 8, 2012 11:26:23 AM
BF3 is graphic intensive. recommend replacing your old gpu with something a little more modern.
m
l
June 8, 2012 11:52:23 AM
That GPU is not good enough and the CPU scrapes as bare minimum.
m
l
June 8, 2012 3:16:54 PM
you cant because your gpu is below recomended spec by a good margin. you need a minimum 88gt/98gt/4850 to get playable frame rates even on low...
Graphics Card (AMD): DirectX 10.1 compatible with 512 MB RAM (ATI RADEON 3000, 4000, 5000 OR 6000 series, with ATI RADEON 3870 or higher performance)
Graphics Card (NVIDIA): DirectX 10.0 compatible with 512 MB RAM (NVIDIA GEFORCE 8, 9, 200, 300, 400 OR 500 series with NVIDIA GEFORCE 8800 GT or higher performance)
yes the gforce 9 series is listed but they mean it must be a gforce *800 where the star represents the series like 8800 or 9800 every card after that must be a *50 or above to play so gts 250 450 or 550 yours being a *400 is just to low...
same goes for ati it must be a 3870 or a 4850 1s you get over a 3870 the requirement drops to *850 so 5850 6750 7750 and so on... the higher the last 2 numbers the better regardless of what series... **20 **30 3750 and under are just to weak.
like i say get a minimum of a 98gt and you will be able to play at least at low settings and get a playable 30 fps minimum.
m
l
