Duke nukem forever starting problems
Last response: in Video Games
Error -
.exe caused an microsoft c++ exception in module KERNELBAse.dll at 001b:75f79673,RaiseException()+0084 byte(s)
i have problems starting up duke nukem forever . as soon as i click .exe , there comes black screen and after some time it comesw up with a cras window
with error like - "DukeNukemForever.exe caused an microsoft c++ exception in module KERNELBAse.dll at 001b:75f79673,RaiseException()+0084 byte(s)".
i tried every thing that has been given on web like running with low specs , lowering antialiasing , lowering resolution , updating redist 2008, applying patch
BUT nothing above works.
SYSTEM :-
phenom ii x4 960T
nvidia 2 x gtx 550ti x2 in SLI
ram 8 gb
nvidia latest up to date graphics drivers (302.xx)
Does this happen in other games? Have you tried to redownload the game? I don't know the game so is it a Steam game? My 550's work best on the 280.26 drivers. Any of the others my system goes nuts.
What does your event viewer tell you? Any time something goes wrong it is log into the event viewer. You meet all the system requirements to play the game on high setting.
What is your OS win 7? You might have to clean it all out before you try to reinstall it so I will link you to a program that will take every part of the game out of your system. There are couple of guys.
On here that would know exactly what to do. If they see this they might jump in. Good luck and get back to us and we will see if it can't be fixed. This link will clean all parts of the game that is removed by just the uninstall.
http://download.cnet.com/Revo-Uninstaller/3000-2096_4-1...
Ask the community
