Archived from groups: microsoft.public.windowsxp.print_fax (
More info?)
Hi Cari, yep all's well in the bios, and device manager says it is working
ok, I tried all the different settings in the bios, SPP ECP ECP+EPP, no go !
and when in SPP mode I disabled ECP mode in the driver, so I think I have
just about covered everything, the printer works fine on my old machine
running Win98, so I know the printer is ok, I do have plenty of USB ports on
the computer, but only have the LPT cable from the printer, I asked at my
local store "Harvey Norman" but they didn't have or know if I could get one,
I will do some ringing round the shops tomorrow, it will give my computer a
chance to recover from all the re-starts
if you think of anything that I
have missed checking ,please let me know thanks
Ray.
"Cari (MS-MVP)" wrote:
> It should work on an LPT connection..... provided of course your LPT port is
> enabled in the BIOS and found in the Device Manager. I have an old (now
> retired) BJC-8200 which I ran on XP Pro for about a year or so with no
> problems.
> However if you have a USB port, it will work better!
> Cari
> MS-MVP Windows Technologies - Printing/Imaging/Hardware
www.coribright.com
> "Ray" <Ray@discussions.microsoft.com> wrote in message
> news:9DDA4725-310D-4554-A7D2-9019E96D713F@microsoft.com...
> > Thanks for the link Mary, I did go through the FAQ's etc. and have just
> > gone
> > through it all again,uninstalling reinstalling etc. I did exactly as the
> > Canon site says, but no luck ! when going through the troubleshooting on
> > the
> > Canon site, it seems to end up giving answers for USB connections, which
> > is
> > of no help to me
maybe I need a USB connection for the 8200, is this
> > possible ?
> > thanks again
> > Ray.
> > "Mary Sauer" wrote:
> >> Canon has lots of support documents
http://consumer.usa.canon.com/ir/controller?act=Support...
> >> Mary Sauer MS MVP
http://office.microsoft.com/
http://www.mvps.org/msauer/
> >> news://msnews.microsoft.com
> >> "Ray" <rayw1@iinet.net.au> wrote in message
> >> news
![:o :o]()
3nQfpGfEHA.2896@TK2MSFTNGP11.phx.gbl...
> >> > Gday all, I have just installed XP Home and can't get my printer to
> >> > print, I
> >> > have installed the XP driver from the Canon site, the install
> >> > instructions
> >> > ars for a plug and play printer , but mine is not usb it connects to
> >> > lpt1
> >> > port, so I sel;ected manual connection and the driver is loaded, but
> >> > when I
> >> > try to print I get ..printer not responding and then printer out of
> >> > paper !
> >> > which it isn't, so I am hoping someone can help me out ,
> >> > Cheers
> >> > Ray
