yep. an unlocked processor is good. apparently all (most) of the 1.4G are unlocked
and yes. im refering to the L1 bridges
cpu overclocking is incresing the multiplier for a faster top Mhz,
motherboard overclocking is basically increasing the FSB (system bus speed).
increasing the multiplier usually gives a greater net mhz increase, but increasing the fsb does much for all round performance. and gives you a better warm fuzzy glow
changing the multiplier is inherently easier. all you have to have is unlocked bridges, a decent heatsink & PSU, and maybe a voltage increase.
increasing the fsb is more touchy as you may be pushing a number of things beyond specification i.e.
the ram mhz, north/southbridge speed, PCI & AGP speeds.
any one of those could cause instability.
for example, my 1200C can run quite happily at either 10x133 (1333) or 9x150 (1350), but the latter gives me a much greater overall speed (more like a 1.4G). only problem ive found is that for some reason i cant run the graphics card benchmarks 3dmark & winbench at 150FSB.
yet i can run 3d games for ages. *shrugs* strange but of little worry.
i can run at up to 154, but beyond that i think my northbridge overheats, or my hard drives dont like it.
Quote from the Hamster: "Why is it that Morons are just smart enough to understand how to breed?"
