extended network problem
Archived from groups: alt.cellular.verizon (More info?)
I just subscribed to the America's choice II plan. I freqently travel to
areas that are in the Verizon network, but I live in an "extended network"
area. If I go about 30 miles North or 15 miles South, I will get into a
digital Verizon area. I can make voice calls at home in the extended area
without any problems, but cannot access the digital service (send pictures,
other data types of services). My question is, would an external antena be
of any help? If so, which kind do you recommend. I have an LG VX7000 phone.
Thanks
9 answers Last reply
More about extended network problem
  1. Archived from groups: alt.cellular.verizon (More info?)
    > travel to areas that are in the Verizon network, but I live in an
    > "extended network" area. If I go about 30 miles North or 15 miles
    > South, I will get into a digital Verizon area. I can make voice
    > calls at home in the extended area without any problems, but cannot
    > access the digital service (send pictures, other data types of
    > services). My question is, would an external antena be of any help?
    > If so, which kind do you recommend. I have an LG VX7000 phone. Thanks
    Fraid an external won't help.. Extended networks are guaranteed to be
    digital VOICE... not data. Don't know where you got the idea that digital
    service is both voice and data.
  2. Archived from groups: alt.cellular.verizon (More info?)
    > Thanks
    An external antenna would most likely not work. However, if you
    purchase an active repeater/amplifier, and set your phone to "Home only"
    you might be in luck. This would be expensive though, as usually the
    full cost is at least $500 for something like that. And it may not work.
    Unfortunately, making and receiving voice calls are the only standards
    on CDMA, and digital features such as voicemail notification, text
    messaging, picture messaging, data use, push to talk, and caller ID are
    not standard while roaming. This is an area where GSM has the upper foot.
    TH
  3. Archived from groups: alt.cellular.verizon (More info?)
    >> freqently travel to areas that are in the Verizon
    >> network, but I live in an "extended network" area. If I
    >> into a digital Verizon area. I can make voice calls at
    >> cannot access the digital service (send pictures, other
    >> external antena be of any help? If so, which kind do you
    > if you
    > to "Home only" you might be in luck. This would be
    > expensive though, as usually the full cost is at least
    > only standards
    > notification, text messaging, picture messaging, data
    > use, push to talk, and caller ID are not standard while
    What??? "active repeater/amplifier"?? 15 miles?? You're
    probably going to need a military license for that kind of
    power...
    and the deal with the digital services is not so much
    standards and more of the extended networks are
    different networks and not VZW... It would be the
    same for GSM. It's a billing issue not so much a
    technology one.
    -Quick
  4. Archived from groups: alt.cellular.verizon (More info?)
    > power...
    > technology one.
    > -Quick
    That's not an unreasonable distance, however, other factors, such as the
    "angling" of the VZW towers could make all the difference. Especially
    if the systems use the same frequency.
    I'm not saying that it's impossible for CDMA to use data/digital
    features while roaming, I'm just saying it's not standard. To the user,
    it doesn't matter whether it's technically impossible or the carriers
    won't allow it -- the only thing that matters is that it doesn't work.
    However, GSM has certain standards. If I'm not mistaken, one of those
    standards (not technical, but of the Group Speciale Mobile) is that
    access to roaming is access to all features, including CID, data, et al.
  5. Archived from groups: alt.cellular.verizon (More info?)
    I've just spent a few days talking to several people in Verizon Wireless
    stores and on the phone. We got caught in the confusion and I don't
    give up that easily. Verizon doesn't tell you exactly what they're
    doing in the America's Choice II plan. It took a bit of doing and
    asking the right questions to get an answer.
    In order to be able to advertise "no roaming charges," they now block
    outgoing calls FROM an extended area where you used to be roaming.
    Verizon is not willing to defray the costs of roaming in another
    carrier's area, so they no longer allow America's Choice II subscribers
    to even make the call. Subscribers on the original America's Choice
    plan can make the call and will be charged roaming fees. Apparently
    they program your phone to differentiate the callers (automatically
    when you do *228 to update as well as when they activate your phone).
    This issue was of special interest to me because I used to be on the
    Digital East plan (until a week ago). In that plan, Verizon picked up
    the roaming charges within my (huge!) home area (the Carolinas to
    Maine, including Pennsylvania). I dropped my Digital East plan because
    many of our minutes are cell to cell and the "in" plan is included in
    all America's Choice plans. In the long run, I am better off by
    switching plans. ("Finally!"--I can hear the Verizon executives
    saying.)
    There is some consolation from Verizon's network being further
    extended, but you will not be able to make calls FROM a
    formerly-roaming area if you are on the ACII plan. If you are on the
    original AC plan, you will still be able to roam and you will be
    charged the additional roaming fees. Unfortunately, this is like
    reducing the size of the candy bar without increasing the price--it's
    still a price increase. In this case, it seems to be a reduction in
    coverage, offset somewhat by a larger coverage area.
    We kept my husband on the original America's Choice plan so that at
    least one of us could make a call when we're on vacation. We were also
    told we have 30 days to change back, so that might be true and you
    might still be able to "undo" the switch to America's Choice II. I hope
    this helps--and please don't beat up the messenger!
    joress
    brought to you by http://www.wifi-forum.com/
  6. Archived from groups: alt.cellular.verizon (More info?)
    joress wrote:
    > We were also told we have 30 days to change
    > back, so that might be true and you might still be able
    > to "undo" the switch to America's Choice II. I hope this
    It's not advertised much but VZW's policy so far has
    been that you can change plans and then, within 30
    days, revert to the plan you had with promos, etc.
    *even if it's no longer offered*.
    That's not to say you might not get *everything* back
    exactly the way it was... There is that business with
    PDA phones and data usage right now where things
    are sort of in flux. I was on the old AC plan with EN
    MOU with my Kyocera 7135 PDA phone. I went to
    switch to the AC1 promo plan they had for a few
    weeks towards the end of last year and the first 2
    weeks of Jan. The CS said everything should remain
    the same. Then she called back in about 15 minutes
    to tell me that the system had flagged my PDA phone
    on the new plan and required that I add a data plan.
    She said she had tried everything and that it couldn't
    be done. My wife's vx4400 was not flagged and retained
    the EN/NA feature.
    She said that she hadn't commited the changes and
    asked if I wanted to go ahead with the switch and a
    data plan. I elected the "pay as you go" plan. She then
    made sure that I understood that the data plan thing
    would be "permanent" and I would not be able to revert
    to the old plan with NA (MOU). Someone else noted that
    they changed ESNs from one 7135 to a replacement 7135
    with no problems so it appears that, currently, the check
    is only done by the billing system when changing plan
    codes.
    -Quick
  7. Archived from groups: alt.cellular.verizon (More info?)
    > Wireless stores and on the phone. We got caught in the confusion and
    > I don't give up that easily. Verizon doesn't tell you exactly what
    > they're doing in the America's Choice II plan. It took a bit of doing
    > and asking the right questions to get an answer.
    I don't know who you've been talking to or what you've been smoking, but it
    is impossible to be on the extended network and roam at the same time.
    Are you sure you aren't confusing a local digital choice plan with americas
    choice?
  8. Archived from groups: alt.cellular.verizon (More info?)
    Joress,
    This subject has been discussed at great length in this and other forums.
    On first glace, it looked like Verizon did limit the roaming capabilities in
    the new, No-Roam America's Choice plans. However, upon further review, it
    was found that only a few counties in the country have less potential
    service than the AC1 plan. The additions significantly outweigh the very
    few losses. Over forty new local areas (SID's) have been switched from
    "Roaming" to Extended".
    In some parts of the country, as an example, one roaming carrier was removed
    from the PRL, but service is still provided by another carrier. We compared
    this over and over and found very little is "lost". Also, there are several
    errors in the map and the PRL, and it seems as though some carriers were
    accidently left out.
    As an example, in Texas, several roaming carriers were removed, but one,
    Cingular, made up for all lost coverage. The net effect is that the state
    lost a handful of (.69 per minute) roaming partners, but included coverage
    has changed from 80% to 100% of the state! In Colorado, one county was
    lost, but one county was gained, and I believe the county that was lost was
    a mistake and will be added to the AC2 PRL.
    Only personal experience will bear this out, but based on the facts, it's
    too early to comdemn the list. I was one of the biggest doubters, I have
    been converted.
    And, if all else fails, even if your phone says "No Service", it is highly
    likely it can complete a 911 call.
    Bill Radio
    Click for Western U.S. Wireless Reviews at:
    http://www.mountainwireless.com
    "joress" <joress.1laeea@WiFi-Forum_dot_com> wrote in message
    news:joress.1laeea@WiFi-Forum_dot_com...
  9. Archived from groups: alt.cellular.verizon (More info?)
    Actually, if your phone says "Extended Network", you are by definition
    roaming (not on a VZW system), otherwise your phone would say "Verizon
    Wireless". You just aren't paying roaming charges.
Verizon Internet Service Providers
