Tom's Hardware > Forum > Mobility Networks > Cingular > Motorola V400 - Battery running short
Forum Mobility Networks : Cingular - Motorola V400 - Battery running short
Archived from groups: alt.cellular.cingular (More info?)
Just got a new v400. But didn't like the battery life. I wonder if I
charged the phone correctly. The manual said the battery is partially
charged at the factory and I should charge it till it says 'charge
complete'. I did that. It took only 2 hours and it lasted about 2
days and 12 hours. That's short comparing to V60's at last five to
six days use.
The manual said *some battery* perform best after several full
charge/discharge cycles, and a Cingular welcome sheet said for *some
models*, the initial charging time is 14 hours. Could V400 and its
battery SNN5683A be one of these models?
Are there higher capacity battery to use with V400?
Sponsored Links
Just got a new v400. But didn't like the battery life,
The Motorola V400 is a Class 4 hanset which means it`s a more powerful
phone than the v60 was. Since it has a higher pull on the network it
uses more power. Also it has a color display will drain battery 25%
faster than the grey scale display. You should charge you phone daily
since its a lith ploy battery and will not get overcharged. That is a
lot cheeper than buying an extended battery. If you must buy a battery
check the Motorola Consumer products website to see if you can find
one or if one is made for your phone. DO NOT USE NON ORGINAL MOTOROLA
BATTERIES. For you to save 20.00 bucks on a battery can cause you to
pay $399.99 to replace the phone at full cost.
Wireless Guy
The Cellphone Guy..
http://cellphoneforums.netView this thread: http://cellphoneforums.net/t116450.html
Reply to Anonymous
In article <Wireless.Guy.14hih3@nospam.cellphoneforums.net>,
> BATTERIES.
Pure unadulterated F.U.D.
Make Motorola rich by paying their 200% markup on batteries.
Reply to Anonymous
"Robert M." <rmarkoff@msn.com> wrote in message
news:rmarkoff-92C51F.09382411042004@news6.west.earthlink.net...
> And your URL for that is?
> And you left out the link that proves you wrong because.....
Congratulations, Robert- you have proved yourself to be a bigger moron here,
than on the Sprint group. Dave is right, and you are wrong. Period.
Reply to Anonymous
"Scott Stephenson" <scott.stephensonson@adelphia.net> wrote in message
news:jfWdnZ1gv_4lxuTdRVn-hg@adelphia.com...
here,
Robert -
Not to worry about the unschooled response(s) to your fact-based post
regarding the characteristics (including charging behavior) of Ni MH/Ni-Cd
batteries. You provided the facts (And a citiation!). Others proved that
some people will not replace their own lack of knowlege with facts, even
when the facts are brought to them, apparently believing that, if they shout
loud enough or assert incorrect information often enough, they can make it
so. This is a general probelm in the nation today, not limited to ignorance
of the physics of battery behavior.
RWEmerson
Reply to Anonymous
And you also left out the URL:
http://www.national.com/appinfo/power/files/f7.pdf
Lithium batteries do not need to be babied. Plain and simple.
> here,
Reply to Anonymous
In article <107ip0amrb4pbff@corp.supernews.com>,
"RWEmerson" <foolishconsistency@hobgoblin.com> wrote:
> Robert -
> RWEmerson
Thank you sir !
Reply to Anonymous
I have a v400 and yes, the battery life is not the greatest. Also, just
because the phone says fully charged it may not be. I would suggest you
charge it for at least 8 hours.
"Nobody" <Nobody@nowhere.com> wrote in message
news:lqg970hd3blggpuhatji52qkts38oddkes@4ax.com...
> six days use.
Reply to Anonymous
There are 1270 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 DustenH won the Uniformed badge
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
