Case Cooling
Forum Overclocking : Cooler and Heatsinks - Case Cooling
I was thinking of taking the air vent from my tumble dryer scewing it to the front of my pc and smacking a hole through the dining room wall and placing the other end of the pipe outside as it can get pretty cold in london this time of the year. My question is would I get problems with drawing cold air from outside or is this a reasonable approach to system cooling?
Sponsored Links
Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Case Cooling
There are 1511 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
Latest best answer
Can someone reccomend a 120mm fan?
By jsc, 10 hours ago:
Go to newegg. Look at the 12 cm fans. Make a table of rated airflow vs. noise (dBA). Don't consider really cheap fgans or fans above your budget. I further discriminate on the type of bearings. I do not like sleeve bearings.
Top experts
