i justgot to case fans in the mail.a front and rear fan. i thought they would be the same size but when i got them today they were different.. the rear is 60mm and the front is 80mm.. the rear is small and does fit in the prefit holes in the rear case .is there a way to change the direction of the fan so i can use the 80mm in the rear to blow hot air out of the pc,and change the 600 to blow air in? and would the small 60mm cool the case enough? well thanks for helping...
JP......
JP......
