Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I just purchased a Lexmark X125 all in one printer. The
printer works great, but Windows stops communicating with
it almost every day for no reason. I have worked with
Lexmark support and reinstalled printer several times.
When I reboot, it works fine for a while, then nothing
until I reboot again. Has anyone had this problem? I do
not have SP2.
Thanks,
burnsnpoodles
Right click on My Computer and select Properties. From the Hardware tab,
select Device Manager.
Scroll down until you get to the Universal Bus Controllers entry. Click on
the + to expand the tree.
Right click on each USB root hub in turn. In the Power Management tab,
UNCHECK the option for the PC to turn off the USB port to save power.
Cari (MS-MVP Printing, Imaging & Hardware)
www.coribright.com
"burns" <anonymous@discussions.microsoft.com> wrote in message
news:05a401c492cd$cd0a93f0$3501280a@phx.gbl...
> not have SP2.
> Thanks,
> burnsnpoodles
Thanks Cari, I have done that several times. That box is
not checked. I am still losing communication with the
printer. And rebooting reestablishes the printer
communication until it decides to stop again, usually
daily, but not on any schedule I can determine.
Diana Burns
>-----Original Message-----
the Hardware tab,
Management tab,
save power.
>www.coribright.com
message
with
>> not have SP2.
>> Thanks,
>> burnsnpoodles
It could be an insufficient power supply unit.
www.coribright.com
news:16e301c49472$ef8b8fa0$3a01280a@phx.gbl...
> Diana Burns
> the Hardware tab,
> Management tab,
> save power.
>>www.coribright.com
> message
> with
>>> not have SP2.
>>> Thanks,
>>> burnsnpoodles
Hi Cari,
How would I find out if power supply is insufficient? It
was replaced 6 months ago.
Diana Burns
>www.coribright.com
message
>> Diana Burns
>> the Hardware tab,
>> Management tab,
to
>> save power.
>>>www.coribright.com
>> message
>> with
do
>>>> not have SP2.
>>>> Thanks,
>>>> burnsnpoodles
PSU's (power supply units) come in all different wattages. I've come across
anything from a woefully inadequate 185 watts to about 650 watts which
appears to be adequate for almost every conceivable device connected to a
PC.
It's actually written on the side of the PSU as to what wattage it is.
news:07c801c495ac$75854bc0$7d02280a@phx.gbl...
> Hi Cari,
> Diana Burns
