Laserjet IIIP Problem
Forum Windows XP : Windows XP General Discussion - Laserjet IIIP Problem
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I have installed windows XP and used printer wizard to set up my Laserjet
IIIP. The printer will work fine for a few days and then I will get an "out
of paper error" message that pops up from the printer icon in the bottom
corner on the start up bar. The printer is not out of paper. The only way I
have found to correct this is to delete the printer and re-install it. I
also have a HP deskjet 672c printer that will do the same thing????
Please help this is getting frustrating.
Sponsored Links
Try entering the settings in the printer driver and see if the option to
enable bidirectional support is available and checked. Also check
setting in computer's BIOS to see where it is set (Standard Printer
Support, SPPO, Bi-directional, EPP, ECP, EPP&ECP. Wording can differ).
Note: a setting of EPP or ECP or ECP&EPP can result in erratic printing
with the LaserJet III.
Check the cable and make sure it is IEEE-1284 compliant or IEEE-1284
certified (IEEE-1284 compatible is not good enough), has no damaged pins
or connectors and is otherwise undamaged.
If the computer has been moved recently, check the PCI cards and
connections in the case to make sure they have not been loosened.
Let us know.
Tom
MSMVP-DTS
"Dave" <Dave@discussions.microsoft.com> wrote in message
news:7FD24706-479C-432C-AC7F-AF43895EA478@microsoft.com...
:I have installed windows XP and used printer wizard to set up my
Laserjet
: IIIP. The printer will work fine for a few days and then I will get
an "out
: of paper error" message that pops up from the printer icon in the
bottom
: corner on the start up bar. The printer is not out of paper. The
only way I
: have found to correct this is to delete the printer and re-install it.
I
: also have a HP deskjet 672c printer that will do the same thing????
: Please help this is getting frustrating.
Reply to Anonymous
Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Laserjet IIIP Problem
There are 1096 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
