G
Guest
Guest
A freind of mine has just recently built me a new computer..with a Abit KG7-Lite mother board and AMD Athalon 1.4Ghz CPU...hes gone on holiday for a month...after building it for me....ive had some problems...with it...
the CPU was reaching temperatures of 52 and 53 degrees..i thought there was a problem with the fan???..so i looked through the KG7-Lite manual...and i noticed it states...
supports AMD Athalon 700MHz-1.33GHz...?? and my processors..1.4 GHz???the bios,,gives me the apportunity to take it to 1.4Ghz..but im worried that its going to make the motherboeard work over..can any one help?? am i safe in using it...the problem is, is that everywhere @ the computer fair..where i got the motherboard from state that..it can be used with 1.4GHz.....can anyone help.......
secondly ive visited a few web sites giving different tempreture reading that the cpu is safe at.......does anybody know what is a safe temperature??? some say 50..and others go as far as 70-80 degrees??? (all confusing)...when my computer reached 52 - 53 degrees...and ive turned it off and rebooted it..it sometime wants to start in safe mode,,and other times comes up with the following error...
during booting up:
after saying "Verifying DMI Pool Data" it says
"Boot From Atapi CDRom: Disk Boot failure, insert system disk and press enter"...........
this is a often accurrance..and after leaving the computer off for a while..and then putting it on again..it starts as normal.......do you think the system is getteing to hot???
Ive moved my tower around a bit..and taken 1 side of the case off.....and now the temperatures gone down to...44 degrees for the CPu and 35 for the system temp...
one finel problem is that somebodies told me that abit motherboards...(i have 6 slots) that i wouldnt be able to use all of them..and after some fiddling around with my Voodoo Tv card (3dfx) i can use slot..1 for sound..slot 4 for tv card and slot 5 for the modem..and the rest seem as if they dont want to play???this chap told me,,this is coz..the other slots are used by the motherboard for something else (sound unusual..but then hey!! i'm not exactly a computer freek...) im just concerned i ve spent alot of money..and it all seems to be going wrong... and i can really appreaciate..now, if i hear that other computer bods are having hard ware trouble...with fans etc...you spend the money and expect it to work???
I'll stop raviting on..and i hope some cam help......seems folks on this site lnow what theyre on about..and too many thanks to the site admin..carry on the good work
thanks...
during booting up:
thanks...
