Hello slg92028;
Did you use System Configuration to setup the Selective mode startup?
If so you can use System Configuration again to configure for a normal startup.
Start -> Control Panel, -> System and Maintenance, -> Administrative Tools, -> System Configuration.
Use the General tab to change startup mode and then check the Load system services and the Load startup items check boxes.
