I have an Athalon xp1800
+ and a super koolance case, pc2100 crucial ram, and a k7t266 pro-ru mobo (http://msicomputer.com/product/detail_spec/K7T266_Pro.htm).
Now here is where I need advice:
I want to overclock, but I read here:
http://accelenation.com/?doc=86
if you overclock and you have pci/agp cards they won't work because your motherboard doesn't have the right dividers. Anybody know about this?
Also would it be worth it to sell the motherboard I have (it is still in box) and get a K7T266 Pro2? would the performance really be that different? and would that have the overclocking problem too? Will nforce be able to be overclocked? It seems there is no overclocking solution until this board comes out:
http://www.iwill.com.tw/xp333/XP333.asp
And does anybody know of a good site tellin you how to overclock the athlonxp, because its bridges are laser cut.
