Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Hi All
My OS is WINXP HED and using M/SOFT Fax with a dialup modem and broadband
for the internet. When I try to send a fax the modem dials but not with the
commom dialup sound. I dont receive any errors but in the fax concole it
says no dial tone and then it trys again with no luck. I was looking at my
event viewer and came across this message.The description for Event ID (
105 ) in Source ( dcfssvc ) cannot be found. The local computer may not have
the necessary registry information or message DLL files to display messages
from a remote computer. You may be able to use the /AUXSOURCE= flag to
retrieve this description; Much appreciated if you could help me to fix
this problem.
Cheers
indiana
Hi All
this problem.
Cheers
indiana
