Connecting PS3 to PC for audio?
Hey guys, I've recently read this thread, and I just want confirmation on something. Is this item ( or ) suitable for connecting AV Multi to 3.5mm? Thanks :)
This is the thread I read
3 answers Last reply
More about connecting audio
  1. Well, the first one is designed to split a 3.5mm signal into 2. For example, you could use it to connect a single iPod to 2 different sets of headphones.
    I believe the second one is what you are looking for. It allows you to connect RCA jacks to a 3.5mm socket.
    If the cables look like that, then yes. Number 2 is what you are looking for.
  2. i believe the 3.5mm input jack on most soundcards is 2.0 stereo only. this might not work out so good if you have a 5.1 system.
  3. That applies to all 3.5mm jacks. They can only transmit stereo. Your going to have to use optical or the colorful 3.5 mm ports if you want 5.1.
Console Gaming PlayStation Audio Video Games
