Printer Sharing Problem
I have Laptop with win7 64 and try to share printer with winxp 32 bit .
I install manually printer driver on laptop. Printer is attached with winXp 32 bit . but when i try to share from win 7 to Xp not working . Solve this problem
2 answers Last reply
More about printer sharing problem
  1. Hi mlpk007 and welcome to Tom's forum.
    Can u see the printer? Do u get some error? Do u have the correct driver for both Win XP and Win 7?
  2. Install inf manually. You will want to use the inf from the windows xp driver package.
    install the 32bit xp driver and install it on the hosting system.
    Then connect to it with the xp machine
    once this has been established then you can change the driver on the hosting system back to the correct driver.
Drivers Laptops Printer Driver Printers Windows 7
