G
Guest
Guest
Soon I will be adding a Geforce2 TI card to my computer. I haven't experienced any heat problems before, But I am thinking that maybe the new card will raise the internal case air temp and give my CPU heat problems. The processor really has pretty lowsy heat control anyway (it has a sizable heat sink on it, but airflow is only provided by the power supply via a black plastic duct). Below is a link to a Pic with a red circle on the black duct. There are holes on the side of the case where the blue box is (I assume the theory is that air will flow in the holes and only across the processor). It's warmer than room temperature in the case now. I can get a internal air tempurature reading, but it will have to wait until morning, there isn't a sensor on the processor itself. The only place there can be a fan is circled in yellow. Do you think the cooling is sufficent assuming I don't overclock or anything like that? Or is an extra fan in the yellow circle and maybe a slot exhaust fan needed?
<A HREF="http://personal.atl.bellsouth.net/sdf/b/u/burns11/G6-450_mc02.jpg" target="_new">http://personal.atl.bellsouth.net/sdf/b/u/burns11/G6-450_mc02.jpg</A>
Thanks
P.S. a front fan could be put in, but I'd have to cut a hole for it and am not really looking forward to doing anything like that.
Thanks
