yeah, you wont have any problem, it is just a nuisance to clean it off once the computer has been in use for a while...
and when reapplying thermal grease, the best way is to clean it off first, then apply...and since i would rather have that be not that time consuming, then i usually keep the thermal grease on the top surface of the core.
yeah, that crazy alchohol is pretty good stuff because it wont leave any residue on the core...it will leave it perfectly clean...
think about this, the doctor will use the same alchohol to clean your arm before he gives you an injection...so if it is good enough for a hospital, then it should be more than adequate for a computer..right?
oh yeah, oldbear....that is pretty crazy...i was just posting something that i thought was random...i mean, i got this thing, and it is cool, and actually does work your arm, but hey, if it will help your arm, then i guess it is not so random.....AHYUK!
-DAvid
-Live, Learn, then build your own computer!-
