Fax and telnet problems since SP2 for WindowsXP
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
Since installing SP2, I have observed the following problems.
1. When booting and the computer is initialing my fax/printer
(HP OfficeJet 600), I get the message "Fax receiver failed to
initialze" - which I presume implies that I will not be able to
receive incoming faxes.
2. Before SP2 I could summon up telnet in Internet Explorer by
entering telnet:// in the address bar. No longer. This still works
with Netscape 7.2, so I presume this has to do with SP2 changes to
Internet Explorer.
I imagine there are switches of some sort that I could set to avoid
these problems without uninstalling SP2, but I have no idea what they
are and how to find them.
1 answer Last reply
More about telnet problems windowsxp
  1. Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
    1. This would have to be HP software because the Windows XP Fax service
    cannot make any use of the Fax features in the your OfficeJet at all. The
    ONLY thing XP Fax knows how to work with is an analog Fax modem; it can be
    internal or external, but it MUST be a Fax modem, not a Fax machine or a
    cable "modem" or a DSL "modem".
    2. I'm going to presume your presumption is correct; I have a number of XP
    Pro machines here, many have had SP2 applied and a number are still at SP1.
    The SP2 machines will NOT launch Telnet from IE and the SP1 machine all
    will. I suspect it may have something to do with this:
    MS01-051: Patch Available for Telnet Logging Vulnerability
    http://support.microsoft.com/?kbid=286043
    and/or the updates made to the Windows Firewall, however, I don't know for
    sure. I'll see if I can find that out.
    Hal
    Hal Hostetler, CPBE -- hhh@kvoa.com
    Senior Engineer/MIS -- MS MVP-DTS -- WA7BGX
    http://www.kvoa.com -- "When News breaks, we fix it!"
    KVOA Television, Tucson, AZ. NBC Channel 4
    Still Cadillacin' - www.badnewsbluesband.com
    "L . Andrew Campbell" <landrewcampbell@earthlink.net> wrote in message
    news:sge9d.5180$UP1.3898@newsread1.news.pas.earthlink.net...
    > Internet Explorer.
Internet Explorer Fax Telnet Windows XP
