Solved
Fullscreen and mouse problem in Battlefield 3
Last response: in Video Games
Related ressources
your way way under spec to be playing at full screen. the hd 2000 is just 1 step above integrated gfx on the old dual core systems. in other words its good for video and basic gaming but you need a gfx card not a video card for high end gaming.
2120 will work well with a 560ti on bf3 single player but will struggle regardless of gfx on multiplayer as bf3 prefers 4 true cores over 3 virtual 1s.
but lack of decent gfx is the biggest problem you have.
Best solution
When I run the game in full screen, the mouse does not work in menu and HUD is not displayed when playing.When I play it in windowed mode,it runs well.I disabled Windows Aero also,the problem persists.
i have the same problem.
Core i7 2630qm 2.9 GHz
8GB 1333MHz DDR3
2GB RADEON HD 6770M
HDTV 1080p
i had this prob but i solved it got to d place where u installed d game open d folder right click on bf3.exe and go to compatibility click on "disable desktop composition" and change the compatibility mode for windows to "vista service pack 2"
