Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > home network printing problem
Forum Windows XP : Windows XP General Discussion - home network printing problem
Archived from groups: microsoft.public.windowsxp.print_fax (More info?)
I have a Home PC running Windows XP Home with a HP 3820 printer attached thru
the USB port. The printer is shared. The Home PC is on a Workgroup and
connected directly to the router.
I have a Work laptop running Windows XP Pro that is connected to my home
network thru a wireless card to the router. The Work laptop is on a Domain.
I have successfully installed the printer on my Work laptop, but have not
been able to print to it since and when I double-click the printer, the print
queue box displays "unable to connect". The host computer (Home pc) is on,
the printer is on.
Sponsored Links
Sorry for the double post. The system said there was a problem after the
first one and I thought I had to repost.
> the printer is on.
Reply to steve
This should work - I do this at home often with a laptop from work that is a
domain member.
When you use the Add Printer wizard (on the work laptop) and add the printer
as a Network Printer, you should get prompted for a username and password.
On that dialog box, there is a check mark for "remembering the password".
If this is not checked, the work laptop will not be able to authenticate
with the home PC.
You should be able to get around this. On the work laptop:
1. open a Command Prompt (e.g. click Start, Run; key cmd; press Enter)
2. key the command:
net use \\homePCComputerName\IPC$ homePCuserPassword
/user:HomePCusername
in the above:
homePCComputerName is the computer name for your home PC (right click on
My Computer, select Properties, select the Computer Name tab)
HomePCusername is the username you use to logon to your Home PC with, or
some other user account you have created
homePCuserPassword is the password for HomePCusername
Then try and use the printer again.
Now, if the user account's password is blank, this may not work, because, by
default, user accounts with blank passwords can not connect over the
network, although they can logon locally.
You can create a user account with Control Panel, User Accounts.
Bruce Sanderson MVP
It is perfectly useless to know the right answer to the wrong question.
"Steve" <Steve@discussions.microsoft.com> wrote in message
news:C06D7093-FDCB-465D-8AF7-D8BA7FAB5D7C@microsoft.com...
>thru
> Domain.
> print
> the printer is on.
Reply to Anonymous
There are 530 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
